installation and lock
ahmetkacar
Re-installation was required because the computer was formatted. It gives an error after installation from cd... about turkish\data... First of all, what is the state of being able to fix it? Secondly, I downloaded a demo from your site, but it still gives a demo warning even though it is locked. I will be glad if you help
Hi, This message indicates that the CD you are using has a reading problem. If the CD is not damaged, wipe it with alcohol (cologne). If the problem persists, we'll send you a new CD. You can call our Bursa office for this. The demo program is set to run unlocked. It is normal for the program to continue working in the demo feature even if you have a lock. Good work
"ahmetkacar":18ip000h" said:
reinstallation was required because the computer was formatted.It gives an error after installation from cd...related to turkish\data... firstly, what is the solution to this. Secondly, I downloaded a demo from your site, but it's locked. However, it still gives a demo warning. I would appreciate your help
Hello Mr. Ahmet, The error you encountered during the installation may be caused by the scratching of your CD or your CD-Rom drive. The demo you downloaded from our website is of limited use. If you are a 6 Version user, Technical support on our site -- You can download the full installation of 6 Versions by following the links > Download --> Program Updates. Or We can send the installation CD of the version you have to the address you request.
First of all, thanks for your interest. I think the cd is corrupted as you said. I will apply for the new installation cd. Thanks again and good work.
Hello, I have a problem with the installation as well. When I say "end of installation" on the computer I normally use, the computer restarts itself. I wonder why this is. Apart from that, when I try to install it on another computer (laptop, vista installed), the installation completes, but when I try to open the program, it gives an error as "unable to access HASP SRM run-time environment (H0033)". And right now I need to solve this very urgent problem. I will be glad if you help. good work...
Hello, Restarting the computer is a normal result that may occur depending on the sharing status of the installed files. However, the program will wait for your approval for this. If the question of restarting the computer appears at the end of the installation, you should restart your computer so that the files that cannot be copied due to sharing can be copied to windows. If your computer turns itself off and on without asking any questions, there may be hardware-related problems in your system. The Unable to access message indicates that the hasp service is currently stopped. 1. The problem can be fixed by turning the computer off and then on. 2. Some antivirus or protection programs may be set at the highest security setting and may be blocking access to the hasp service. You can temporarily disable the security for hasp setup. 3. Hasp driver may not be installed correctly and completely. You can download the hasp program from the link below and re-install it.
Good work...
Thanks for your attention, but it didn't work: Q 1. I restarted. did not turn on I disabled the 2nd antivirus, also the windows firewall is turned off. still not opened. I think the link you gave is wrong. It says "page not found".
There is no problem with the link. You can download by right click on it, save as different. Uninstall hasp-related programs from the add/remove programs section. Turn the computer on and off. Download and install the hasp program in the link. (keep protection programs turned off at this stage)
could not be downloaded, it says can't connect to server :S Also, there is no prgoram like Hasp in Add-Remove Prgoram. I reinstalled from the cd and it won't load it either. I couldn't understand anything. Do you have any other suggestions, Mr. Hakan?
Thank you Mr. Hakan, I think we solved it as a result of your patience for 23 minutes :) again, it was a problem that occurred because I didn't completely turn off the antivirus...
I downloaded idecad 6 from the idecad site, but the hasp key foun text appears, but the hasp you sent to the forum does not accept it for 5.22
"architect_kar":1x1vwxwv" said:
idecad 6 I downloaded it from idecad site, but hasp key foun text appears, but the hasp you sent to the forum does not accept for 5.22
Hello, I wonder if you haven't upgraded to version 6? If you have a license, you will get a lock error when you download and install version 6 exe.
good evening. I hope someone on the forum sees my msg and can help me. I have been using ide for almost 6 months. I brought it home from work, but it gave the error HASP SRM Run-Time Environment(h0033). It gave this error on my first download, but I installed hasp and it worked. until I uploaded the demo of another static program to my computer at work today. It didn't cause any problems at my workplace, but when I got home, it gave this error. What can I do. Who can I call for technical support. I need to do a project, I got a lock, but it was a problem. Good evening.....
I already installed it before I sent you a msg. I wonder if the demo of another static program affected me. Will something like this break the lock. Because the lock is not on me. The workplace. It did not work, so this...
There is no physical deterioration of the lock. Try turning off your anti virus and firewall programs, uninstalling all HASP-related drivers from the control panel and reinstalling them. If it doesn't work, you can contact our Bursa office by voice.
Anyway, thank you. I was surprised. I'll call the bursa office in the morning now, they won't pick up anyway. I plug it into the computer. The red light on the back is on. And even though I did what you said, it gives the same error. Thank you, thank you...
