Insights questions on using ideCAD Architecture 8
MEHMETSIRAY
SN: IDE OFFICIALS... I HAVE NEWLY STARTED USING THE ARCHITECTURAL VERSION 8.029 1-WHEN WORKING ON THE PROJECT WHILE THE WALLS ARE SCRATCHED, THE DOORS WINDOWS SOME OF THE DIVAR SCANNING STAYS ON THE DOORS WINDOWS SOME OF THE DIVAR SCANNING WHEN I TRANSFERRED TO THE TWO LENGTHS OF THE LANDINGA LANDAMS WE ARE STAYING 2-MAUSUN İLMECİ DOES EXTREMELY JUMP, SO IT IS HIGHLY MOVING IN THIS STATIC, IT CONTINUES EVEN WHEN I REDUCE THE VALUES FROM THE SETTINGS BUTTON, THE DRAWING HAS NEGATIVELY AFFECTED OUR COMFORT. THE NAME AND THE LOCATION WRITING COME INTO EACH OTHER, BY TOLBAR, WHEN WE PLAY WITH THE VALUE, IT CORRECTS, BUT THIS TIME, BETWEEN THE COATING AND FIELD WRITINGS ARE LOVING TOO MUCH... THESE ARE SIMILAR I WAITING FOR ANSWER...
Re: ARCHITECTURE - 8 QUESTIONS ALSO I DIDN'T SEE THE "EDIT ENDPOINT" COMMAND IN THIS VERSION... A COMMAND I USE IT A LOT TO BE INSTALLED
Re: ARCHITECTURE - 8 QUESTIONS While using version 8, sometimes I have to open version 7, I recorded version 8 by opening a separate folder p. It's not in files... my problem is that my favorites in version 8 are deleted when I open version 7, I tried for 1 hour and I did 7 deleted, what's the problem?
Re: ARCHITECTURE - 8 QUESTIONS also ver 8. give 7 after i made my settings. when i open it all my aryls become original, same give 7 is happening
Re: ARCHITECTURE - 8 QUESTIONS IN ARCHITECTURE 7 PROFILES WERE STORED IN IDECAD.mdb under the data/ideCAD/database/architectural section folder
IN 7 I WAS COPYING MANY PROFILES I CREATED WITH COPY AND PASTE TO ANY COMPUTER I WANT. THERE IS NO SUCH FILE IN ARCHITECTURE 8 OR WHERE ARE THE PROFILES SAVED HOW CAN I LOAD MY PROFILE LIBRARY...?
Re: ARCHITECTURE - 8 QUESTIONS SIMPLE Vaulting CANNOT BE DRAWN IN ARCHITECTURE 8 WHEN WE DETERMINED THE SECTION, WHEN WE PRESS THE RIGHT KEY OF THE SECOND MOUSE, TONO DOES NOT OCCUR
Re: ARCHITECTURE - 8 QUESTIONS STATICS AND ARCHITECTURE 8( PLANS) IF I PLACE THE APPLICATION PLANS SIDE-BY-SIDE AND MAKE 2D WITH THE EXPORT TO TWO DIMENSIONS COMMAND, THERE IS NO DRAWING WHEN I MAKE A ZOOM BORDER...?
"MEHMETSIRAY":i5okitj1" said:
FURTHER, I DIDN'T SEE THE "ENDPOINT EDIT" COMMAND IN THIS VERSION...I REQUEST A COMMAND I USE A LOT
+1
"MEHMETSIRAY":qzxxlx67" said:
SN: IDE OFFICIALS... I HAVE STARTED TO USE ARCHITECTURE 8.029 VERSION 1-I HAVE STARTED TO USE ARCHITECTURAL VERSION 8.029 THE SCAN REMAINS WHEN I TRANSFER TO TWO LENGTHS, THESE SCANS CONTINUE AT THE NORMAL PLAN AS THE SCANS STILL REMAIN... WE HAVE TO CORRECT IT MANUALLY 2-MAUSUN İMECI MAKES VERY OVERJUMPING BUT MULTIPLE MOVEMENT CUSTATULARUTUMERUTIC SUSTATUMA SUSTATUMSUM SUSTATULARDETUMSUT IT AFFECTS... 3-THE REASON IF WE END THE REGISTRATION WORK MANY TIMES, IT TAKES A LOT OF SPACE IN THE MEMORY 4-WHEN PLACING THE LOCATION, THE NAME OF THE LOCATION AND THE LOCATION WRITING COME INTO EACH OTHER WHEN WE PLAY WITH THE VALUE FROM TOLBAR FROM THE VALUE OF THE TOLBAR FLOOR... I WAITING FOR ANSWER TSK...
1)This is a situation we know, it will be fixed as soon as possible. After drawing your works in ideCAD 8, ideCAD 7' You can also open it and handle the output stage there. 2) Change your settings to default settings and look at the situation again, Settings / General Settings / Drawing / Capture Sensitivity / DN jump factor 3 , Selection distance is 5 pixels default settings. You may have changed this. 3) It is set this way because file loss is not desired, if you want, you can increase the time from Settings / General settings / Automatic recording / Interval. 4) Location Settings/Texts/Distance between texts is 0.05m by default. You may have changed this. If it does not change, you will get a view like the one below.
"MEHMETSIRAY":1cj89tyn" said:
FURTHER, I DIDN'T SEE THE "EDIT ENDPOINT" COMMAND IN THIS VERSION...I REQUEST A COMMAND I USE MANY TO BE INSTALLED
Click on the Object , you can do it with a tug on the nodes. The method you mentioned was a feature of the old version. This command was removed because it came with a more practical feature.
"MEHMETSIRAY":nnf46xwt" said:
CANNOT DRAW A SIMPLE Vaulting IN ARCHITECTURE 8 WHEN WE DETERMINED THE SECTION, THE SECOND TIME WE PRESS THE RIGHT KEY OF THE MOUSE. If you install 8 and search, we'll connect and see.
"MEHMETSIRAY":1vpf5cir" said:
ARCHITECTURAL PROFILES IN 7
data/ideCAD/database IT WAS STORED IN THE ideCAD.mdb FILE under the /architectural section folder. I WAS COPYING MANY PROFILES I CREATED IN 7 BY COPY AND PASTE TO ANY COMPUTER I WANTED. ARCHITECTURAL 8 IS NO FILE SUCH. OR WHERE PROFILES ARE REGISTERED. The file extension, which was ideCAD.mdb in 7, was changed to ideCAD.ipro in ideCAD 8. If you save your file with .ipro extension and save it to Local Disk(C:)/Program Data/ideCAD/database/Architectural Sections, your profiles will come.
"MEHMETSIRAY":p195lrz1" said:
STATIC AND ARCHITECTURE 8( PLANS) FOR EXAMPLE, WE PLACE THE APPLICATION PLANS SIDE-BY SIDE AND MAKE OUR 2D SYSTEM WITH THE EXPORT TO TWO DIMENSIONS COMMAND WHEN I MADE THE ZOOM. It does not appear on the screen....?
This problem occurs when it is called to create 2D drawing more than once.The situation has been reported to Arge.
Re: ARCHITECTURE - 8 QUESTIONS Good evening, Mr. Mehmet, you can view the explanation about the situation you mentioned below from the pdf below.
"MEHMETSIRAY":1dlzv9dp" said:
When using version 8, sometimes I have to open version 7. I recorded version 8 by opening a separate folder, not p. files... my problem is that my records in my favorites in version 8 are deleted when I open version 7, I tried for 1 hour 7 deleted what is the problem?
Re: ARCHITECTURE - 8 QUESTIONS I CANNOT SEE THE RAILINGS I CREATED BY ARZU HANIM ARCHITECTS UNDER THE "RAILING" FOLDER, THE PROGRAM HAS CREATED BUT I CAN'T SEE MY OWN RAILS...
Re: ARCHITECTURE - 8 QUESTIONS I HAVE MENTIONED ABOVE THE RAILS I HAVE DEFINED, EXAMPLE." LIKE "GLASS KOR-1, FERFORJE-1" I CANNOT SEE THERE IN THIS FILE.
Re: ARCHITECTURE - 8 QUESTIONS ALSO BEZEN THE PROGRAM IS VERY DELAYED UPLOADING THE PROJECT....? THIS GENERALLY HAPPENS WHEN UPLOADING THE SAME PROJECT MANY TIMES. IT BACK TO NORMAL AGAIN WHEN I TURN THE COMPUTER ON AND OFF...?
Re: ARCHITECTURE - 8 QUESTIONS Greetings, Mehmet Bey, it stems from the situation I explained in the PDF above. The types you just created in 8 are written in the Railing folder under ideCAD. If you open 7 without renaming the ideCAD folder, 7's ideCAD folder will be nailed on top of the other, so the railing folder will also change. If you do your next work in accordance with the explanations in the PDF and do not switch between versions frequently, you will not have any problems.
"MEHMETSIRAY":9tiw1bi9" said:
I HAVE MENTIONED ABOVE THE RAILS I HAVE DEFINED EXAMPLE." LIKE GLASS KOR-1, FERFORJE-1", I CANNOT SEE THERE IN THIS FILE
