HakanŞahin
Administrator
Dear Users, You can download the ideCAD Architecture V6.2 program using the link below:
Log in or register now.
List of possibilities: 1. New ideCAD Render and render engine -Global Illumination (Photon Mapping/Irradiance Cache) -Parametric daylight and sky lighting (country/city/date/time) - IES lights (photometric lights) - Imperfect refraction/reflections - Illuminated objects - Unlimited multiprocessor support - Parametric grass/hairy carpet making -Ambient occlusion -Realistic fresnel reflection model -Hemispherical environment map for sky background or using "physical sky" -Camera effects (vignetting, DOF lens blur, gamma, exposure control) 2. Parametric curtain wall object -Quickly prepare the curtain wall element diagram as desired, with line, arc or spline contours ability to draw -Outer frame (border), Modeling with horizontal recording, vertical recording and different panel groups -Creating glass-to-glass combined curtain wall designs easily by hiding the profiles from one or both sides of the facade -With flexibility such as deleting the desired surfaces on the facade, adding doors-windows, rotating glass and solid panels in the desired axis being able to make special designs -Be able to bend linear one-piece curtain walls to make an angle with the horizontal -Trimming facades angled with horizontal with the integration of curtain wall / cut with roof 3. New "material edit" command for selected objects in ideCAD Render 4. Command to select one or more objects and select the same objects on all floors. For example, in a multi-storey building, being able to select some of the balustrades and jambs on one floor in perspective and select them on all floors at once 5. Defining frequently used objects in object settings and calling them with a single command (such as interior wall, parapet wall, exterior wall, etc.) saving and recalling sets) 6. Automatically taking the upper level of the lower element (site, terrain, other libraries, etc.) while placing library elements 7. The box is free with rotated and extended objects Ability to use object modeling techniques 8. Optional scanning of library elements in plan. 9. Automatic trimming and connections at intersections of arcs, circles, splines and straight walls 10. Diversification of combination combinations formed at the junction of layered walls 11. Wall the ability to decide which side of the wall the profile objects will be placed on (space bar) while drawing a profile object based on the base (skirts, floor moldings, borders, etc.) 12. When "select all" is clicked in the door-window mode, all doors and windows are displayed. can be selected at once. 13. Drawing the jamb and profile objects (skirting, floor molding, border, etc.) on the plaster in the plan 14. Drawing the floor molding up to the jamb border if there is a jamb 15.[/ b] Being able to see subfolders under the main "texture" folder with the new material editor 16. Ability to save and upload ready-made material library and materials as "imt" file compatible with the new rendering engine 17.[/ b] Transferring 2D objects from ideCAD Architecture to ideCAD Render Good work...
