No, sir, I mean the black screen set. The drawings are usually made on a black screen, it is available in ide static in order not to tire the eyes, and we want the same for ide architecture in 9 versions, which is very useful. Thank you."NYILMAZ":1m97taw5" said:Ms. Seda, I think what is meant here is the desire to automatically change colors, especially in colors from black to white, when transitioning from a white screen to a black screen. In AutoCAD, the lines you draw on a black screen turn black when they switch to a white screen. I guess that's the demand. Of course, such an option may not be available for all colors, but I think there should be such an arrangement for the most used black and white.
Then it's worth expressing that. There are black screen sets in both 7 and 8. When you open a new project, you can use the black screen set. Moreover, as seda lady said, you can use both the background and all the objects. You can set it according to the black screen option. Then you can use it as a template project and use these settings in all your pros. In V8, there are not only black background sets, but also screen sets such as gray etc. Check the attached pictures. Sets and drawings are visible in the pictures."bartayd":2hlryc1c" said:No sir, I mean black screen set. It is not available in 7 and 8 versions, I don't want to deal with individual colors, drawings are usually done on black screen, it is available in ide static and very useful in ide 9 versions as well. We want architecture. Thank you.
All of the pictures are STATIC. I SAY IDE ARCHITECTURE I HAVE 8 demos and only white screen."NYILMAZ":2yefbslt" said:Then it would be useful to put it that way. Both 7 and 8 have black screen sets. When you open a new project, you can use the black screen set. Moreover, as seda lady said, you can set both the background and all objects according to the black screen option. Then you can use it as a template project and use these settings in all your pros. In V8, there are not only black background sets, but also screen sets such as gray etc. Check out the attached pictures. Sets and drawings are visible in the pictures."bartayd":2yefbslt" said:No, what I mean is black screen set. It is not available in 7 and 8 versions. Thank you.
