ideCAD Architecture black background
bartayd
good day, can you add the drawing page with black background to 9 versions like the one in idestatic. Of course, with updated colors and pen thicknesses according to the black screen. I hope it will be very useful for ide users.
Hello; Black background set is already available in ideCAD architecture. There is also an option to set the desired background color in the general settings of the program. Take it easy, good work..
Ms. Seda, I think what is meant here is the desire to automatically change colors, especially in colors from black to white, during the transition from white to black screen. In AutoCAD, the lines you draw as white on the black screen turn black when they switch to the white screen. I guess that's what demand is. Of course, there may not be such an option for all colors, but I think there should be such an arrangement for the most used black and white.
"NYILMAZ":1m97taw5" said:
Ms. Seda, I think what is meant here is the desire to automatically change colors, especially in colors from black to white, when transitioning from a white screen to a black screen. In AutoCAD, the lines you draw on a black screen turn black when they switch to a white screen. I guess that's the demand. Of course, such an option may not be available for all colors, but I think there should be such an arrangement for the most used black and white.
No, sir, I mean the black screen set. The drawings are usually made on a black screen, it is available in ide static in order not to tire the eyes, and we want the same for ide architecture in 9 versions, which is very useful. Thank you.
"bartayd":2hlryc1c" said:
No sir, I mean black screen set. It is not available in 7 and 8 versions, I don't want to deal with individual colors, drawings are usually done on black screen, it is available in ide static and very useful in ide 9 versions as well. We want architecture. Thank you.
Then it's worth expressing that. There are black screen sets in both 7 and 8. When you open a new project, you can use the black screen set. Moreover, as seda lady said, you can use both the background and all the objects. You can set it according to the black screen option. Then you can use it as a template project and use these settings in all your pros. In V8, there are not only black background sets, but also screen sets such as gray etc. Check the attached pictures. Sets and drawings are visible in the pictures.
"NYILMAZ":2yefbslt" said:
"bartayd":2yefbslt" said:
No, what I mean is black screen set. It is not available in 7 and 8 versions. Thank you.
Then it would be useful to put it that way. Both 7 and 8 have black screen sets. When you open a new project, you can use the black screen set. Moreover, as seda lady said, you can set both the background and all objects according to the black screen option. Then you can use it as a template project and use these settings in all your pros. In V8, there are not only black background sets, but also screen sets such as gray etc. Check out the attached pictures. Sets and drawings are visible in the pictures.
All of the pictures are STATIC. I SAY IDE ARCHITECTURE I HAVE 8 demos and only white screen.
The template in the attached zip file is for V8.5 projects (I don't know if it will open without problems in the demo) Open the files here and install the 8 version, the black template, if you haven't changed the installation folder, by default for Architecture "C:\Program Files\ideCAD\ Place it in ideCAD Architecture 8\Templates\structural\New Template Project" folder. For V7, open the attached sample file and copy it to the address shown in the attached picture. Note: Pay attention to the addresses for the demo.
Also, take a look at these pictures. You can also make a simple template project. (Drawings drawn with V7) Note: I receive architectural projects drawn with a black background from many of my friends.
