Heaviness in the project file
ebasakin
Good day, there is a serious weight loss in the attached file, I wait at least 5 minutes even when I get an appearance. Even working with a mouse is still very difficult. It's not really a big project, but for some reason I'm having this problem. In IdeArchitecture, when the project has grown a little bit, I always experience contractions.
Hello Ertuğrul, your project is not very big, but quite a lot of three-dimensional libraries were used on 2 floors. Therefore, you are experiencing slowness in the cross section. If you select the libraries from the list of uncut objects in your defined section and view settings, you can get a view in a few seconds.
I assume you are working with version 7. As a solution to the slowdown in perspective; It will be useful to use one or more of the methods by pulling the perspective detail option from the bordered solid model to the solid model, selecting all the libraries at once and activating the "draw as contour in 3D" option from the library settings, reducing the libraries in the duplicate layers or just turning off the layer. I couldn't see any slowness in the plan, but if you want, you can show the libraries as contours by selecting image / object contour drawing / select contour objects from the image menu. In addition, in version 8, your project can be used very quickly in perspective. In the new version, necessary optimization has been made in this regard.
