Door-Window Spaces
serdagi
Hello, in the project I sent attached, I can see the door and window openings in the plan, but not in the views. I would like your help as to where I went wrong. Let me briefly describe the project; It will be a single storey boiler room building. There will be 50 cm foundation, 70 cm basement and 550 cm floor height. I defined the sub-basement curtains under the walls as normal curtains and lowered the level to obtain 70 cm. I did it by adding 70 cm to the defined elevation values of the program when placing doors and windows. thanks everyone
Hello, The reason why the door and window spaces do not open; that you define the door and window to the curtain walls. The curtains under the wall appear in front of the wall when we look at the plan window, select the curtains passing under the wall, click the right mouse button and enter the drawing order and send it to the background. Thus, you will see the wall, not the curtains, on the plan plane, place the windows and doors in this way. As far as I can see, the door between Q-8 will be at the intersection of the curtain and the wall, do not delete the door here, let the curtain also be defined. Let's design the walls according to the door. Take it easy, good work.
