Did you know that? (Hint)
Under the Layers submenu from the right-click menu that opens by pressing the right mouse button, you can close/unlock, lock/unlock, change the layer on an object basis[/b][/i][/u] You can also access the Layer Settings from this menu. Operation steps: -> Click the right mouse button anywhere in the drawing window. (If the right-click menu is not active, press and hold Ctrl.) -> Under the right-click menu that opens, there is the Layers submenu. -> Perform the operation you want to do under the Layers submenu.
For structures with rigid basement floors, the period control required in TBDY 2018 Article 3.3.1.1.b is made automatically in the program and is given under the heading Period Control for Rigid Basement Acceptance in the dynamic analysis reports. Process steps: -> Analyze after defining the rigid storey structure. -> Get dynamic analysis report.
In the perspective window, you can bring the image to the starting position of the program (the angle visible from the origin point) by pressing the "Home" key on the keyboard. Operation steps: -> Press the Home button while the perspective view is active. Perspective view of the building from any point of view: Perspective view of the building after pressing the Home button:
You can find the command you are looking for by using the command search line at the top right of the program window in the ribbon menu, and you can find the command you are looking for and run it automatically. Operation steps: -> Click Command Search line in Ribbon menu. -> In the search line, start typing, for example, Rectangular Column. As the command is typed, the commands that match it will begin to be listed. -> Select the rectangular column from the list. -> The program will direct you to the rectangular column icon, then the command will run automatically.
You can filter the information of the data entry as a color palette in the "Analysis system display options/Visualization/Reinforced Concrete/Data" tab in the Right-click drop-down menu on the 3D Screen (filter ) Example screenshot according to slab thicknesses:
While opening the program, if you hold down the Ctrl and Shift keys at the same time and click OK to the warning that appears in the background, you can return the program to its default settings. After this process, the program will also ask for your ribbon menu selection.
Tools/Geometry Check or Geometry Check[/u from left toolbar By clicking the ] icon, you can check your project for errors/warnings for any floor or for the entire project. Operation steps: -> Click on the Geometry Control icon from the toolbar. -> In the dialog that appears, mark the states to be checked for geometry. -> Click the OK button. The program will notify with a dialog whether there are problematic situations, and if there are, it will list the problematic objects.
In the General Settings dialog, if the "Right button Show Menu" is marked, if the right mouse button is pressed together with the "Ctrl" button, the last command worked will be activated. . If "Show menu with right click" is not checked in the General Settings dialog, if the right mouse button is pressed together with the "Ctrl" button, the right button menu opens.
You can customize the commands used in the command line in the dialog that opens by clicking the Settings/Command Line Editor icon. The Command Line Editor dialog contains a list of defined commands and their shortcuts. Changes can be made if desired.
You can use the Settings / Static Materials command to change the concrete and reinforcement classes of the reinforced concrete objects in your project on an object basis. Operation steps: -> Click the Static Materials icon from the Settings menu. -> You will be able to see the list of reinforced concrete elements in the opened program -> After marking the element whose concrete or reinforcement classes you want to change, select the appropriate concrete, reinforcement type and stirrup type from the drop-down list and click the OK button to close the dialog.
If you want to use the classic menu instead of the ribbon menu, you can uncheck the "Use ribbon menu" option from the General Settings dialog. When you close the program and open it, the classic menu will become active. Similarly, you can tick the option to work with the Ribbon menu.
There are reinforcement exposure options for metering from the "Drawing>Tools>Rebar Exposure Settings" dialog. You can choose according to your purpose. Process steps: -> Make your selection from the Drawing>Tools>Rebar Pose Adjustment dialog. -> Analyze. ->In the drawing, reinforcement pose numbers will be created according to your selection.
Whichever command you are working in, you can get help about using that command by pressing "F1 key". Example of F1 help key when in curtain command:
With the "Dynamic Input" feature, you can instantly enter the length and angle information while defining the object. During the process, you can switch between length-angle values by pressing the TAB key on the keyboard. To turn on dynamic input; -> Open the General Settings dialog. -> Click the polar tracking tab. -> If the dynamic input option is unchecked, tick it and close the dialog. Let's draw a 500 cm long line with an angle of 60 degrees for example with the Dynamic Input option: -> Click the Line command and click the drawing area to give the 1st point of the line. -> Type 500 from the keyboard. The length value will be 500 cm. (If your unit of operation is meters, type 0.5) -> Press the TAB key on the keyboard. The cursor will land on the Angle box. (If you press the TAB key continuously, the cursor will jump to the angle and length information boxes in order.) -> Type 60 as the angle value. -> Click the left mouse button or press the Enter key, a line will appear.
With the "Show vertical frame" command, you can click an axis to display the vertical plane (frame) of the elements on that axis, either as a solid model or as an analysis model. as you can get. You can also enter data by staying locked in that plane. Operation steps: -> Click on Show image/vertical frame command. -> Click an axis. Example 7 axis vertical frame view:
In any dialog, the unit list can be opened by clicking "right mouse button" on the text box, you can change the working unit at any time. Unit change operation on sample concrete fck: The same operation is also valid during data. Unit change operation in the example beam dialog:
After the report is created, we can change the units to be used in the report output by clicking the "Unit Setting" icon in the toolbar in the report program. Process steps: 1. Get report. 2. Click the Unit Setting icon in the report program. 3. Change the unit used according to your preference and click the OK button.
"Curtain head regions can be displayed with the desired color and hatching by selecting the scanning type and color for the curtain cap areas from the screen and column application drawing settings." Operation steps: -> Click on the drawing column application plan. -> Click Settings in the dialog that opens. -> Click on the scan box opposite the screen scan line. -> Specify the color and scanning type as desired. -> Click the OK button to close the dialog. -> When you get a drawing, your curtain title areas settings will be displayed in color and hatching.
When you click on an empty area in the drawing area and move the cursor from left to right, you select only the objects within the rectangle, and when you move the cursor from right to left, you select both the objects within the rectangle and all the objects that the cursor passes over. Moreover, you can do the opposite by holding down the shift key during the process.
After receiving the report, if the project has errors listed in the report, click the Project Errors menu or bug tracking shortcut keys(F5, F6, F7, F8)[ to see the errors in order. You can use /u]. Process steps: After receiving the report, use the error keys or click the relevant line under the Project Errors menu. Previous error: F5 key. Moves the cursor to the previous error. Next error : F6 key. Moves the cursor to the next error. First mistake : F7 key with cursor. takes you to the location of the first error. Last mistake: F8 key. Moves the cursor to the location of the last error.
