cross-section or view problem
Double click the screen. Then move it to the starting point so that the elevations do not change. (check if there is an infinite part in your drawing)
Hello, I think you accidentally moved or copied an object too far. To delete, first select your build in perspective. Apply the invert selection command and press delete. Cut again. If it still doesn't work, you can send your project to [email protected].
We reviewed your project, it was created due to a problem caused by faulty roof drawing. The edited version of the project was sent to you by e-mail at the beginning of last week.
