Levent Özpak
Active Member
In the project you added, in the Analysis Settings / TBDY Options tab "You must set the 1/3 condition in the curtain overturning moment calculation. Take into account the contribution of the tie beams (Nv) that do not provide the same " line is marked. The reason for the change in the ratio of the shear wall overturning moments when the basement walls are defined is that this option is selected. Without this option, the Mdev values are close to each other in projects with and without basement walls. This is the current state of the regulation. It does not allow the option to be checked. We recommend that you review the posts on the subject at the link below."muhendise":2g2hcdvz" said:I uploaded the project, first analyze it in its first form, then delete the 50 cm basement curtains and analyze what I meanYou do not have permission to view link Log in or register now.
Good work
