"inş.müh":b8asu5in" said:
			hello, the total overturning moment (Mo) I understand from the regulation is the shear force on each floor multiplied by the height from the base of the building and then summed up. Can we see this way in the reports, just like in the alfas calculation, or is the program calculating this way for each floor? Calculates the force and the corresponding largest base tipping moment according to Equation (4B.7) and combines the mode contributions of these quantities according to 4B2.4. For example, the X direction is n. for mode More precisely, the modal floor shear force for each mode is obtained by multiplying the following quantities; Vtxn = mtxn x SaR x Tn Vtxn = Base shear modal effective mass x reduced design spectral acceleration x Vibration period Overturning moment for each mode is also obtained by multiplying the Vtxn value of each floor by the floor elevation as shown in the formula. These values calculated for each mode are combined according to 4B2.4. As of v10.05 we give the combined values. These values calculated for each mode will be published in the future versions.
 Hello İsmail, it is commendable that you give an answer immediately, this must be the difference of the idea, it is not multiplied by the Vibration period when only Vtxn is found. SaR(Tn) this expression is the reduced design corresponding to the nth vibration mode. is spectral acceleration so Vtxn=Base shear force modal effective mass x reduced design spectral acceleration, I think you wrote that by mistake
