Hello, I'm getting certain errors in my project and I'm not sure about the quantity, can you help
Log in or register now.
--Ry=7, take A15, model the --3 axis foundations like D axis. Ünver ÖZCAN"cvlngnr":1jy9mqrn" said:Hi, I am getting certain errors in my project and I am not sure about the quantity, can you help me
Any chance you could help?"puncover":3pbvpnou" said:Hello. I couldn't get over the shear force problem of the Perge Group. Could you also give some advice about the project, please? The flooring system is cassette. There will be a car park in the basement and there is a 40 cm step. I can't add curtains in the X directionYou do not have permission to view link Log in or register now.
The drawings in the program are in accordance with TBDY page 122, figure 7.7."MaFiAMaX":26kp5npr" said:Hi, 1-) ideCAD modeling logic does not allow beams to pass over the curtain. When you connect the beam to the curtain end, the analysis model is formed correctly. The reinforcement of the beam is also drawn into the wall according to the rules in the regulation. However, in reality we continue that beam over the wall in the formwork plans. So you manually extend the beam lines in the formwork plan. K49 and K53 beam reinforcements also need to be drawn continuously. This is a problem in terms of structural analysis. It is not, but it creates a deficiency in the production of the project. It is among the notes of the software team, but I do not know when the continuous drawing feature will come.
Everyone may have different preferences, but the program complies with the regulations and does it correctly, I expressed it. It is enough to do it as shown in the figure. In my opinion, there is no benefit to doing it all the time and it is a waste of equipment."MaFiAMaX":wlp17vpb" said:@sahinsukru, Please read what I wrote carefully again. "[/b]I already wrote.
Hello, -There are errors in both projects in terms of basic data entry. the foundations should be defined by clicking on the curtain end nodes to form a continuous foundation under the curtain.For all curtains, it would be appropriate to make a definition as you defined under the P1 curtain in the project named 4.ide10. In the project named 4.ide10 with -screen, the basement curtains connected to the floor curtains were defined to overlap the floor curtain For example, the right joint of the P22 curtain is connected to the left joint of the P24 curtain. Arrange the joint points of the curtains to be compatible with the end nodes of the floor curtains. -There are differences between the floor heights and the height of the basement entered with the curtain and the foundation and the entrance in the projects. -When you enter data with the sub-basement curtain, it is expected that the quantity value will be higher due to the increased curtain length. When the foundation is drawn continuously, the sprouts and vertical and horizontal reinforcements of the curtain cause more quantity than the longitudinal and transverse reinforcements in the continuous foundation. Good work."cvlngnr":1prfp3jc" said:hello, is it normal to have such a difference in size between a project that I designed with a continuous basis and a project that I designed with curtains? =https://we.tl/t-tVl7iEBHJs]https://we.tl/t-tVl7iEBHJs[/url]
'-Both projects have errors in terms of basic data entry. The foundations connected to the walls in a rigid direction should be defined by clicking on the wall end nodes to form a continuous foundation under the curtain. In all curtains, it would be appropriate to make a definition as you defined under the P1 curtain in the project named 4.ide10. ' I got a positive result when I arranged the foundation in line with your advice, thank you for your interest and I wish you good work"Emrah YILDIZ":2elx17yt" said:Hello, -Both projects have errors in terms of basic data entry. The foundations connected to the walls in a rigid direction should be defined by clicking on the wall end nodes to form a continuous foundation under the curtain. In all curtains, it would be appropriate to make a definition as you defined under the P1 curtain in the project named 4.ide10. In the project named -curtained 4.ide10, the basement curtains connected to the floor curtains are defined to be above the floor curtain. For example, the right node of the P22 curtain is connected to the left node of the P24 curtain. It is convenient to connect P22 from the left node. Arrange the nodal points of the basement curtains connected to the floor curtains in harmony with the end nodes of the floor curtains. -There are differences between the floor heights and the height of the basement entered with the curtain and the foundation and the entrance in the projects. -When you enter data with the sub-basement curtain, it is expected that the quantity value will be higher due to the increased curtain length. When the foundation is drawn continuously, the sprouts and vertical and horizontal reinforcements of the curtain cause more quantity than the longitudinal and transverse reinforcements in the continuous foundation. Good work."cvlngnr":2elx17yt" said:hello, is it normal to see such a difference in size between a project I designed with a continuous basis and a project I designed with curtains? these days, there are places where I get stuck with the footage and I'm trying to understand exactly why. I would be glad if you help.You do not have permission to view link Log in or register now.
Hello, -Create a new layer from the layer settings. -Select the D7 tile and tile edges. -Assign it to the new layer you defined with the change layer command. -Close the new layer you defined and define the tile named D86. Then you can open the layers. In the example a similar definition was made by defining the layer named 'Tile 2', you can check it out. Good work."tavekkul":2fmyogf5" said:Hi. I want to define two tiles on top of each other due to the difference in elevation as seen in the attachment. The tile edge cuts the bottom tile. How can I solve this. Thank you Hello.
