About material assignment
saridurmus
Greetings, When I want to assign a Material to the Material, some materials only have a name, but there is no color in return, the reason is blank.
Hello, from the Settings tab, enter the materials command. In the material list that opens, you will see that some materials have a question mark. Select one of them by double-clicking, select the empty gray area opposite the dock. Show the texture folder you use from the folder section as the target folder. Say ok and exit. You don't need to do this every time, just show the target folder for the material once. Take it easy, good work..
