3D floor plans
Hello, it is not possible to create text in perspective view in İdecad Architecture. You can only create it in idecad render and save it as a ktp2 file, add the file to the idecad library and call it as a library element. Good work
Hello, run the 1.ideCAD rendering program. 2. Create your text in 3d with the text command. 3.After creating your article; Click on the "Create automatic plan" icon (the plan image will appear on your working screen.) Here you can make any two-dimensional intervention you want. Determine the holding points with the ''Automatic definition point'' command (in the plan view) Specify your limit with ''Auto-create border'' command (in the plan view) 4. Save the file as ktp2 file with the File/Export/ktp2 command. 5. Move the saved ktp2 file to ideCAD Architecture/Libraries' folder. 6. Run the ideCAD architecture program and insert the relevant library. You can find more detailed information in the ideCAD Render help for creating text and libraries.
Hello, We created an image by taking a screenshot of what you need to do and we present it to you in the attachment. Good work.
