Hello, It seems that only Sae(T) value is calculated in the excel you added. Equivalent. According to 4.8, the SaR(T) value should also be calculated and this value should be defined in the program. When calculating the SaR(T) value, a plateau region should not occur on the graph, since it is considered to be greater than TB and less than TB. Good work.
