Working on imported files (dwg)
Kemal Baş
I cannot do enough operations on the dwg extension files that I imported. For example, I cannot perform operations such as drawing axis, placing columns etc. on any architectural plan drawn. I will be glad if you provide information on the subject. Good work.
Hello, The drawing limits of the dwg file you imported may be set too large and the drawing exceeds the drawing limits. You can see the limit values in the coordinate box. Move the bottom corner of the drawing to the origin point and scale the drawing so it stays within the drawing limits. If you scale the drawing to 1 meter=1 unit, you will work more comfortably...
