If you take 2 renders at the same time in high resolution, it is quite normal to experience a shutdown due to a memory problem. Moreover, making 2 renders at the same time on the same computer will not save you time. If 1 render is finished in 20 minutes and the second render in 20 minutes, it will take an average of 35 minutes to render both at the same time instead of 40 minutes. Also, your suggestion on the forum a few weeks ago; "ideCAD Render working unlocked while rendering" has been taken into consideration and made available in 7.01. After opening ideCAD Render 7.01 with the dongle on another machine and starting the render, you can remove the lock and open ideCAD Architecture 7.01 on the other machine and get the 2nd render there. After the lock is released, rendering will continue on the other machine. Increasing the resolution is necessary for large prints. For example, if you are going to print a 2 m * 2 m sign at 70 dpi and hang it on the construction site, 5500 * 5500 pixels is sufficient. This quality will give good results for images to be used outdoors. Signs, photoblocks, etc. of the same size to be hung indoors at eye level. 7800*7800 pixel resolution (for 100 dpi) is more than enough. (It may even be smaller.) I do not prioritize the issues that directly affect the quality of the image, which I have mentioned many times under other headings (a good architectural scene, the use of correct and enjoyable materials, the position of the sun, the details that increase the reality, the well-crafted landscape, etc.). Trying to solve the render quality with exaggerated high resolution will only waste time in proportion to the expected render time. My advice is to decide where and in what dimensions the scene you will receive will be printed, select the print sizes in the render settings, keep the dpi value between 70-100 and render at the resolution suggested by the program.
