When the floor plan is rendered, there is a wall inside the door.
u_yet
Hello, When I render the floor plan, the space scans are not available on the bases of the doors... The wall continues here. I would be very happy if you write what can be done. I am sending an attached sample.
Good afternoon, if you place box objects on the base of the doors equal to the wall thickness and with the same space texture, you will get the look you want. Another way is to paint the area there with the painting program. When you cut the roof with a dark color, it can make the cut color look better.
