1) Beam loads should be visible on the beam, and even depending on a button (by turning it on and off), the loads should be visible or not. Now we can see the loads, but we need to hover over the beam and wait for the mouse, we cannot see all the beams at the same time. 2) We want to be able to enter the elevations separately as the lower level and the upper level in sloping floors. It will automatically calculate the slope according to these elevations. When we slope the existing normal slab, the slopes of the beams on its sides change, their shape is distorted. 3) It should also show the columns on the curtain sides and the reinforcement connections in the curtain openings. Also, the column-beam junction area detail and the column vertical expansion sheets should be combined in a single sheet and each vertical opening should be prepared with its own connection detail. Thus, the number of layouts will decrease, the drawings will be more comprehensive, more understandable and more beautiful, and it will also save time for ide users. 4) In the vertical expansion of the column, optionally similar vertical expansions on the same floor can be shown in a single drawing. We already show stirrups with similar openings together in a single stirrup, and we want those columns with similar stirrups to be displayed in a single vertical expansion. 5) In stud beams (even in beams requested by the user) it should be able to tighten stirrups in the same range along the entire beam. 6) In double stirrup beams, there should be at least one constructive reinforcement on 8 corners of the stirrups, and especially the two longitudinal reinforcements in the upper and lower middle should be placed in a way that exactly coincides with the corner points of the stirrups, we want the necessary arrangement to be made for this. 7) In particular, in short beams with body reinforcement, the overlapping of the letters is prevented, it only happens on short beams. 8) Double stirrups and three stirrups can be optionally made in the columns. 9) Inclined beams should be shown obliquely together with the reinforcement expansions. It is showing straight now, it should be visually understood in the beam detail that the beam is inclined. 10) In column application drawings, I want crossties to be drawn in an s-shape automatically or optionally. The curtain details are s-shaped and very beautiful. 11) In the process of selecting the concrete classes to be used in the building elements in the project general settings, it should be possible to change all of them at once. 12) Additional reinforcements placed in the raft foundation drawing are sometimes very small (like 80 100). I want these additional reinforcements to be drawn as at least 150 cm as the smallest length. If there is additional reinforcement, set the smallest length to 150 cm. 13) A new column should be opened on the quantity page and the total of all the equipment going to that floor should be written in this column, and the total of the grand total should be written at the bottom. Currently, the floor total exists for each type of reinforcement, but the sum of all reinforcements does not exist for each floor and as a grand total. 14) In the numbers given on the metering page, punctuation is used in the hundredth steps, and dots should be used in the thousandths. For example, let it be given as 55.930.28, not 55930.28. 15) Base column, curtain sprout reinforcements should be added to the quantities under or within a title. 16) While taking the quantity, I should be able to take the quantity of only the elements I have chosen. We can only see the reinforced concrete calculation of the selected elements, just like this, we should be able to take the quantity of only the selected elements. 17) We should be able to give the curtains the upper right level and the upper left level. (Changing height curtain) 18) When I change the axis names on one floor, it should automatically change on the other floors as well. (Apply the settings in general settings to all drawing windows does not work. ) 19) In the column toolbar, there is a centered column icon for the vertical axis, but a docked column icon is also needed for a horizontal axis. We want this icon to be added to the column toolbar 20) The user should be able to use any type of reinforcement on the beams they want (only when they select them). It will not make any changes to unselected beams. 21) I just want to get the quantity of the beams I have chosen. Only the beams I selected should be in the metering list, not the others. 22) I want the beam reinforcements extending into the wall to be longer in beams that are inserted parallel to the long side of the wall. should be extended to half the level of the curtain. take it easy, good work
