Dear dears; v6.0011 is the service version. As a new possibility, the possibility to intervene in the diameter of the ampatage distribution reinforcement has been added only in the foundations (You can give the diameter you want from the basic parameters dialog). In addition, optimizations were made to reduce memory usage during the analysis. Apart from these, the situations reflected to us by our users during the 45-day period that the program was in use were corrected. (Often deficiencies/fixes brought by the new report format). The geometry control from v5 has been removed for now as it cannot meet the evolving needs of the new infrastructure in v6, and will be added as a more useful carrier system/analysis system control command in the future. In line with the demands of our users, version 5 did not give a warning at the beginning of the report in the column-beam junction areas, there was no change in that regard. New possibilities for use will be in version 6.0050, which will be released a few months later. To give a few examples (Without the right to change): -Earthquake using optional response spectrum solution and distributed masses in the elements Ability to perform account and regulation checks. -Improvements in the use of rigid diaphragms, solving curved rigid diaphragms, defining certain floors as separate rigid diaphragms, opportunity to examine rigid diaphragms in 3 dimensions. - Improvements in raft calculation - Possibility to examine element loads and raft ground stresses in 3 dimensions - Completely rewritten column application plan to meet the majority of user requests. -Some improvements in other drawings -The ability to save projects in old version format (will be valid from version v6.0011) -Using different title and layout formats in drawings and applications, user-defined letterhead types -A few conveniences in examining long reports -Improvements in automatic naming of elements -Shell form Speed optimization in the solution of paneled systems and data entry -Automatically converting 2D drawings into 3D building elements -Inputting wall and window spaces in the static program and transferring loads to beams automatically. -Conversion of quantity reports into new format -Some improvements in reinforcement selection algorithm -Assigning concrete and reinforcement classes to the elements on the basis of type as in v5. -Papier, plinth and floor wiping object for the architectural program just a part of the newly added possibilities in 6.0050.
