What you said is different. You want to open a project drawn in AutoCAD with İdeMİMAR and get a cross-sectional view. Everything you draw in IdeCAD is in the logic of a smart object (that is, the column knows that it is a column, the wall knows that it is a wall). Every operation, including appearance, is based on this logic. However, everything in AutoCAD consists of lines. Even the 3D drawings you make are lines that have been given features. Therefore, you cannot take a section from the plan you get from there. But I can say an easy method. IdeCAD is also used by other program with a certain logic. There is a command to return the prepared lines to their own smart objects.I also overlay them in my static project as an example. I show it in the attached picture. With the 2D project arrow command, you can easily convert some lines you draw into IdeCAD objects. (column, wall, axis, etc...) In this way, the process of redrawing the plan is shortened and you can take a section over it. This is what I understand from what you wrote. I don't know if you mean something different."ebrargns":1vlzcj59" said:I got the autocadden idecade floor plan like this, but I want to take a section view over it Can't I make corrections over
