Unable to resolve system in "modal" installation
hades57
In my project, it gives an error that the system cannot be resolved in modal installation. I will be glad if you help.
Re: SYSTEM CANNOT SOLVE ON "Modal" INSTALL Various data entry errors are being made on consoles as I have shown in the attached attachment.
I am getting the system cannot be resolved error. There is no problem with the geometry control. I didn't see any problems with the nodes either. I would be glad if you help.
"barsesa":xz3pcnr3" said:
I get the error "The system cannot be resolved. There is no problem in the geometry control. I did not see any problem in the nodes. I would appreciate your help. I would appreciate your help.
Hello, when the slab edges of the D04 landing slab are arranged as in the attached project, the analysis is performed. Note: The beam K06 is given a positive level in the basement. The columns S06 and S09, to which the beam is connected, must be given an upper level. Vertical continuity must be ensured by giving a level to the relevant columns on an upper floor. Good work
