transferring idecad settings to idecad on another computer
mimariproje
There are 2 computers in our office, one of them is older than the other, this new one is more performant, naturally, since the other computer has been worked before, library project settings and so on. Since the settings are on that computer, what can be done to move them to another computer and work in the same order.
Re: idecad settings transferred to idecad on another computer Save the project you are working on and adjusting the settings as different and clean the drawings inside Save and exit. Take the project to your other computer, follow the path Computer/Local Disk(C)/Program Files/ideCAD/ideCAD Architecture 7/Templates/Architectural and drop the file you brought from your other computer into the opened folder. Run ideCAD Architecture, click Project/New, under Start using template you will see the file you want to draw with its settings. Select it. Launch using template; It helps to open a new project page with the desired settings. For your second question, opening your file by holding down ctrl+shift will return you to the initial settings. If you are opening a new project, use the Start using Default(Reset settings) command.
