The section comes out in one color (in the same project, 1 of them is colored)
emirh
Hello, My problem is this. I want to take 2 sections. I can get 1 color without any problem, as I want. Although I use the same settings as in the previous section (via transfer settings), it produces only one color. What could be the problem? The elements subject to the cross-section have the same properties in both, I couldn't make sense of it. If I have to open it, in the 1st section, every material comes out in the color it should be. The load-bearing elements that enter the wall-window section are in different colors than the roof plaster. But in the 2nd section, it cannot assign any color other than the color 67 normally assigned to the column beam trace and the color 68 assigned for the roof construction. I am sharing the images below. COLOR SECTION:
SINGLE COLOR SECTION:
It would be great if you could help. I'm glad it's a little hurry
Re: The cross section comes out in one color (in the same project, 1 of them comes in color You have to look at the settings while taking the section. If you install Team Viewer 8 and call our Istanbul office, we'll see.
Re: The section comes out in one color (in the same project, 1 comes in color Hello, I guess your problem is that you may have taken the section when the section bb (5-5 section) was in static mode. I recommend you to check it. Take it easy.
