Takes the measure from outside the polygon column
demir
where I want it to throw the measure is the red line, but for some reason it always takes it outside the polygon column (black line).
Re: emergency help (DIMENSIONS) Hello, Since dimensioning is done by selecting an object in the outer dimension command and the polygon column is a single object, the measurement takes the entire polygon column. When dimensioning, you can select up to the wall and then measure the polygon column with free measurement. Take it easy, good work.
