System Unresolved Error
suatyy
Hello Mr. Hakan, there is no problem in geometry control in the project I added. There is no problem in the 3d frame and analysis settings, but it says the system cannot be resolved during the analysis. The architecture is made and taken from 5 versions. Suat Yildirim
The elevation of your K9, K17 and K5 beams has been entered incorrectly. If you enter these beams on the floors where they should be (on an upper floor), your problem will probably be solved.
Thanks for the reply, it was solved by changing the elevations of the mezzanine beams, but here is another situation. Beam elevations should not be defined above their own floor. I guess this control should be included in the geometry control.
