Due to the building structure I need to use semi-rigid diaphragm analysis. But I am getting the following error. I remodeled the building 4 times. Due to the architectural structure of the building, there are different levels between the floors. I modeled the jeans by entering minus g and got the same error. I modeled each elevation difference by taking different layers, and I got the same error again. With the fully rigid diaphragm, the analysis ends smoothly. The geometry check does not throw an error that would interfere with the analysis. When you turn the building at an angle of 45 degrees, sometimes analysis passes with the rotate building command. But I need to model it this way to fit the map.
			Thanks in advance for your help.3:38 Calculating design spectra: "O". 4:06 Modal analysis in progress: "¦Modal E1". * Using the Ritz method * 4:21 ***************************** 4:21 ********** *********** CANNOT SYSTEM LOADING "¦Modal E1".************************* 4:21 FEM ERRROR, ERROR CODE = -200 4:21 Problem joint number : 34 4:21 Node coordinates: X : 40.37 Y : 12.07 Z : 11.39 4:21 ******************** ********* "¦Modal E1" - Memory used for stiffness matrix : 83 MB Total used memory : 90 MB 4:21 Analysis aborted. 4:21 Analysis cancelled.
	 You do not have permission to view link
		Log in or register now.
