Stress error at raft foundation
friends, if anyone has any information on this subject, I would appreciate it if they could help, it's an urgent job, thanks
Select the negative ground stress option , then analyze , compare the magnitude of the value , if it is negligible you turn off the option . In other words, it is entirely up to your engineering, make a clear analysis and examine the results, good work.
"YasinTezel":1yuu8syg" said:
If you have made the corrections I mentioned, please send the final version of your project and we will examine it. Make sure you enter the "ground bearing capacity". Sent from my LX1 using Tapatalk
