Re: STEEL ROOF ON CONCRETE COLUMN Hello; As stated by 2m Proje, there is a serious burden on your lovers. Your live load value and snow load value are high. If these loads are the correct load values for you, there is nothing that can be done. Only the forehead and gusset junction of the purlins on the consoles, which are close to the column, overlapped with the top plate, so I arranged the eccentricity, not divided from the intersection, so that you can switch with the UPN 180. Good work.
