umutozalit
in continuous foundations, according to how many times the diameter of the reinforcement used was calculated according to how the sprout lengths were calculated in the last sheet
In version 6, the message says "where can you change the size of the colon sprouts attached to the foundation" Parameters/General Reinforced Concrete Settings" Note: The length of the other column shoots drawn in the program is in accordance with the default 1.5*lb earthquake code and you do not need to change it normally. Why do you need such a study?"schen_54":3qs5jpwy" said:HOW TO CHANGE COLUMN sprouts EVERY TIME I CHANGE IT IN 2 DIMENSIONS.. I'M TIRED NOW.. Glad if you could help...
