sprout lengths
umutozalit
in continuous foundations, according to how many times the diameter of the reinforcement used was calculated according to how the sprout lengths were calculated in the last sheet
The sprout lengths can be adjusted in "Parameters/General Reinforced Concrete Settings" by giving a factor of fi or lb. If you are making your project according to the default settings, the sprout lengths are 1.5 times lb.
HOW CAN I CHANGE COLUMN sprouts EVERY TIME I CHANGE IT IN 2 DIMENSIONS..I'M TIRED NOW..I WOULD LOVE IF YOU HELP ME...
"schen_54":3qs5jpwy" said:
HOW TO CHANGE COLUMN sprouts EVERY TIME I CHANGE IT IN 2 DIMENSIONS.. I'M TIRED NOW.. Glad if you could help...
In version 6, the message says "where can you change the size of the colon sprouts attached to the foundation" Parameters/General Reinforced Concrete Settings" Note: The length of the other column shoots drawn in the program is in accordance with the default 1.5*lb earthquake code and you do not need to change it normally. Why do you need such a study?
