You will calculate the wall shear area on the relevant floor and enter these values in meters2 in the Akx and Aky columns. You can get help by pressing the F1 key in the floor parameters dialog."ertub_23":2yw1na15" said:I understand that you said thank you, but yes, the wall weight can be entered on the beams on the mezzanine floors, but what I mean is on the ground floor, since we cannot enter the wall weight on the foundations, we can express how soft it is to the program . Also, in the "Analysis/ Floor Parameters/ Irregularities tab, you can intervene in the wall, column and curtain cutting areas." In the section, no values are written for the elements.
