S sonerizgi New Member Jan 15, 2019 #1 When I solved the system as a semi-rigid diaphragm with Idecad Statik v10... I cannot control the slab tension...
D drohendx New Member Jan 23, 2019 #4 "sonerizgi":2jay4924" said: When I solved the system as a semi-rigid diaphragm with İdecad Statik v10... I can't provide slab tension control... I would appreciate your help... Click to expand... I have the same problem.
D drohendx New Member Jan 24, 2019 #6 For now, if you solve it completely rigidly, you will not encounter a problem.
