Hello. We have solved the high ductility of our project, which I added in the link, as it is ribbed in both directions (with 80cm-80cm cassette sizes), which is called cassette system, but we put 2 curtains due to the condition of the structure (R=7). However, we could not fix the following errors. We ask you to check if there is a place we missed. - We especially got the error of insufficient shear force on all floors of the p5 curtain (even if we enlarge its dimensions. We can't just change its direction). Columns close to the P5 curtain I mentioned above. -Although the relative floor offset exceeds the limit value only a little on the ground floor, we cannot save it. We also tried increasing the system rigidity. (Concrete class c30, increasing the column size, etc.) -And after a few analyzes, the raft basically gave a ground safety error. I would appreciate it if you could look into it and help with solutions. Thanks in advance. Download link;
	 You do not have permission to view link
		Log in or register now.
                     German
 German  French
 French  Spanish
 Spanish  Portuguese
 Portuguese  Italian
 Italian  Arabic
 Arabic  Russian
 Russian  Japanese
 Japanese  Turkish
 Turkish
