M mustafa ali New Member Jan 30, 2013 #1 When I open a roof space on the roof I created, the roof elements are deleted on one of the roof surfaces. How can I solve this problem? Thanks
H hatice New Member Jan 30, 2013 #2 "mustafa ali":1u9hg466" said: when I open a roof space on the roof I created, the roof elements are deleted on one of the roof surfaces. How can I solve this problem? Thanks Click to expand... Hello Mustafa Ali, Select the roof, click the right button and select the roof in the right click menu. select the split into surfaces command. This way you can solve the problem. Good work...
M mustafa ali New Member Jan 31, 2013 #3 thank you very much, you helped, i tried it right away and it worked
