roof solid masonry machine room
arembero
Hello, I have a problem, I would appreciate if you can help. In the attached project, the machine room will be designed as a masonry on the roof floor. I also entered the machine room as on the roof floor, but I can't get an analysis. The system cannot solve, check the geometry. I get the error. I would be very happy if you could help me what to do. Thank you in advance.
Hello, You are getting the warning that the system cannot be resolved because there are unsupported beams on the attic floor. No data entry can be made in this way. If the engine room is to be built as masonry, you can enter the loads consisting of the masonry section as an additional load on the relevant elements on a lower floor. I would also suggest you to evaluate the comments on the subject in the link below.
Good work
"arembero":1htz1fos" said:
Thanks for your answer, I have one more question. What is the extra load I need to add to the countryside on the lower floor? Linear slab load is for slab slabs It is not taken into account in hollow slab calculations Extra loads can be added to the covering load of the slab.
