Re: ROOF MATERIAL LIST You cannot get a material list in the section, since no composite material definition is made on the roof. Copy one of the site list in the section of the project you are working on. Blast the block. Replace the text with the material names you want to be included in the roof layers with the replace text command. Then select the lines and texts together and save them as blk with copy to file. You can take this block from all your projects with the paste from file command and use it.
