Reverse beam problem
mine.y.
There are trapezoids in the axles due to the land, as far as I understand, idecad does not like the trapezoids very much, on top of that, we couldn't get out of the problem when a reverse beam was made. The beams on the 1 axis will be reverse beams, but the program keeps giving errors. "Exceeded maximum margin, there are objects with insufficient cross-section or not conforming to the rules" and it gives B problems on columns. We tried everything possible, changed the column sizes, changed the orientation. It's okay when we make a straight beam, but we have to make a reverse beam. We are using the 5.511 version of İdecad, the project is being solved in the demo of the latest version, is there a problem with the version? Good work.
Hello, This question, which you sent to the Technical Service via e-mail, has been answered via e-mail. "If positive elevation is given to the beams to make inverted beams, the columns to which the beams are connected must also be given an upper level. Vertical continuity must be ensured by giving elevation to the same columns on an upper floor."
