return the library element
BSTtasarım
Hello, how can I make the selected library elements in the plugin italic (like rotating 90 degrees clockwise or 90 degrees counterclockwise)
Hello, Import the related library to ideRender with the option "Transfer the relevant library to ideRender" or open ideRender in the installation and import the objects you want to ideCADRender by saying .ktp2 import. With the rotate command, you can rotate the angle you want. The plan image will appear on your working screen. Here you can make any two-dimensional intervention you want. After deleting the existing border, definition points and plan from the drawings, define the holding points with the command "Determine automatic definition point" (in the plan image) Indicate your border with the command "Create automatic border" (in the plan image) File/Export/ktp2 Save the file as ktp2 file with command. Move the saved ktp2 file to ideCAD Architecture/Libraries' folder. Run the ideCAD architecture program and insert the relevant library. -- Take it easy, good work..
Hello, you can call our Istanbul or Bursa office and get support through your project with remote access. Take it easy, good work..
