Render Problem - Too slow....
M-Ayinsaat
Under normal conditions, I can render a 640x480 design quality render in 1 minute, but now I can't get it even in half an hour, so I have to render 7000x8000 pixels. Global lighting takes too long. Where could the problem be? I'm using 7.01. I downloaded version 7.014 but it gives an error before running the setup wizard. Computer features; intel i7 4gb ram 2gb nvidia Thank you Güneş Aydın
You may not have set your render settings optimally. There may be more than enough light sources in your project, there may be illuminated object material that escapes your attention. If you send your project, we will help you with the settings.
The project and textures are in the link below in a compressed form, I would be glad if you could help. I need to render 150 dpi from camera 2 with 1.2mx1.6m, recorded angle of view. By the way, the ram of the computer is 8gb...
Thank you Gunes Aydin
I'm using
"M-Ayinsaat":f2gbgs96" said:
7.01. I downloaded version 7.014, but it gives an error before running the installation wizard.
What kind of error do you encounter. If you call our Bursa office, we can discuss the problem...
The situations that I have determined in your project are as follows: 1) The dimensions of the object you use as a land element are excessively large. Since ideCAD's new rendering engine works on a physical basis, the use of such large (land) and small-sized (structure) elements together causes disproportionateness in light calculations and slows down the rendering. In addition, erroneous results can be obtained as an image. An area of approximately 500x500m will do your job for this render. This is the primary reason for the slow rendering in this project. (When you shrink the land, 640x480 rendering takes about 3 minutes). 2) Max. reflection 3 is left. This is a level that is rarely required (it is used to see an object by reflecting like a mirror from 3 surfaces.) In a typical architectural project, max. You rarely need to set reflection more than 1. This is a factor that will slow down the render. 3) You left the gamma setting at 1.1, the standard gamma setting should be 2.2. Depending on the effect, this setting can be played in the range of 2-2.4, but a setting like 1.1 will still give an unrealistic result. 4) I think you tried the user-defined settings to find the reason for the slowness, but the settings like 1 photon count are a bit ridiculous. For typical daylight outdoor rendering, the medium quality setting will do 90% of your work with no adjustments. You can get the final render on high or at the highest setting, but it won't make much difference with the medium setting, especially for outdoor rendering.
Thank you for your help. When I called the office about the problem with the 7.014 installation, I explained it and I think we solved it, I may have downloaded the installation file incorrectly. I'm going to apply what you told and try rendering. Thank you so much. Hope I can handle it. Good work. Good luck with. Sun Aydin
