raft thickness
LEYLA YÜKSEL
IN MY B+Z+2 STOREY PROJECT I HAVE AN INSUFFICIENT RAID THICKNESS I MADE AS 40 CM. I ALSO USED THE CLEAN CLEARANCE OPTION IN THE EDIT SECTION OF THE REINFORCED CONCRETE ACCOUNT AXLE, BUT THERE WAS NO SOLUTION. Glad to work.
Hello, The distance between the columns (Ln/30) is checked in the raft foundation thickness control. In cases where there is no column in the raft, the raft opening is taken into account in the thickness control. If you think the thickness is sufficient, you can interfere with the "Reinforced Concrete Calculation Axle Edit" command to the line of the reinforcement axles -clear opening for thickness control-. Good work
"Levent Özpak":225uq7f9" said:
Hi, The distance between the columns (Ln/30) is checked in the raft foundation thickness control. In cases where there is no column in the raft, the raft opening is taken into account in the thickness control. If you think the thickness is sufficient, "Reinforced Concrete Calculation Axis Edit" You can intervene in the line of the reinforcement axles with the command -clean clearance for thickness control.Good work
WITH THE NEW INCOME UPDATE, I CONSIDER BODRUM SURROUNDING CURTAIN WITH 30 CM AND 25 CM IN THE SAME PROJECT FROM THE UPPER FLOOR CURTAINS, FROM THE LOWER FLOOR CURTAIN WARNING.
"LEYLA YÜKSEL":2hh18lor" said:
IN THE SAME PROJECT WITH THE EARTHQUAKE CURTAIN THICKNESS WHICH IS 30 CM AND THE BODRUM SURROUND CURTAIN IS 25 CM WITH THE NEW INCOME UPDATE, I RECEIVE THE WARNING OF THICKNESS FROM THE UPPER FLOOR CURTAINS AND THE DOWNLOAD CURTAIN'S THICKNESS.
You can ignore this warning if it is given in case the thick curtains continue to the upper floor in the systems that are formed.
"Levent Özpak":14zqb1sn" said:
"LEYLA YÜKSEL":14zqb1sn" said:
NEW UPDATE WITH THE EARTHQUAKE SCREEN THICKNESS IS 30 CM, THE BODRUM ENVIRONMENT CURTAIN IS 25 CM IN THE SAME PROJECT FROM THE UPPER FLOOR CURTAIN.
If the warning you mentioned is given in systems consisting of a combination of curtains of different thicknesses, if the thick curtains continue to the upper floor, you may ignore this warning. This is in our notes. If you are talking about a different situation, could you add a sample project?
THANK YOU...
"LEYLA YÜKSEL":34hygh0j" said:
NEW UPDATED WITH EARTHQUAKE CURTAIN THICKNESS IS 30 CM, AND ITS BODRUM ENVIRONMENT CURTAIN OF 25 CM IN THE PROJECT I GET A THICK WARNING FROM THE UPPER FLOOR CURTAINS FROM THE LOWER FLOOR CURTAIN.
If the warning you mentioned is given in systems consisting of a combination of curtains of different thicknesses, if thick curtains continue to the upper floor, you may ignore this warning. This is among our notes. If you are talking about a different situation, sample project Could you add me?
THANK YOU...
The thickness warning in the geometry control is due to the situation I stated in my previous message. Good work
