"elifgorel":2y22ln0l" said:hello, why doesn't idecad add additional reinforcement in the raft basic solution? When you solve the same project in a different program, there is no additional reinforcement even though the upper and lower reinforcements are the same. If it is met with minimum pursantages, it means that there is no need for additional reinforcement.In this case, additional reinforcement is not discarded....
Hello, the thickness requirement to be complied with as per the regulation is not met. determines the free span used for thickness control according to the position of the reinforced concrete calculation axis.You can see the free span value with the calculation axis edit command, you can change it if necessary."matrax":3eml4v38" said:somehow the raft does not save the thickness of the foundation, the man says, the only thing is the raft, the foundation will go into the car or something, I am doing something wrong, somehow I did not save the thicknessYou do not have permission to view link Log in or register now.
