Raft basically unable to create network error
zekaikc
Hello, In the attached project, when the thickness of the raft base is increased to 50 cm and the analysis is performed, I get the error that the mesh cannot be created. What could be the reason? Good work
"zekaikc":bsw4n7y2" said:
Hi, In the attached project, when the thickness of the raft foundation is increased to 50 cm and analysis is performed, I get the error that the mesh cannot be created. I wonder what the reason could be? Good work
Hi, In the project you have added, the raft slab networks are not formed correctly. choose "base-superstructure" connection method "Direct connection" Good work
"Levent Özpak":17d6a66k" said:
"zekaikc":17d6a66k" said:
Hi, In the attached project, I get an error that the mesh cannot be created when the thickness is increased to 50 cm on the mat foundation and the analysis is performed. What could be the reason? Good work
"zekaikc":3gr5gso4" said:
Thanks for your reply. How can I examine whether the raft flooring mesh is correct or not. Also, could you briefly explain the difference between "direct connection" and "enlarge connection area" option?
- You can examine whether raft slab networks are formed from the analysis model. -Rat foundation-superstructure connection method; It determines the area where the column - curtain load will be distributed. With the "direct connection" option, the load is given to an area equal to the column-wall width. With the "connection area enlargement" option Load distribution is made to an area equal to the given rate.
Hello there; The edge of the raft slab remained under the Tk06 beam. (Also, this beam coincided with the raft slab). When deleted, networks are formed in the analysis.
