Raft basic reinforcement range
hydrkrmn
I can't keep the spacing of the raft foundation additional reinforcement at 10 cm. It drops to 4 cm. The municipality says to have a minimum of 10 cm, but it doesn't work.
In the selection of reinforcement, you have selected only 12 and 14 reinforcements for additional raft reinforcement. In a 13-storey building, in the 65 cm thick raft flooring, missing AS occurs because larger reinforcement diameter cannot be selected. If you want to increase the reinforcement spacing to 10 cm, you should increase the raft thickness and/or choose a larger diameter of the raft reinforcement. Note: It also seems that there are elements with incorrect floor level after the geometry check.
Mr. Hakan, you are right, but since it is the 4th earthquake zone in the Niğde region, iron with a diameter of 16 is not used. These additional reinforcements are formed around the elevator curtain, do we have a way to prevent this in general. So is there a difference between solving this raft foundation in parts and solving it?
"hydrkrmn":2nheu075" said:
Hakan, you are right, but since the nigde region is the 4th earthquake zone, iron with a diameter of 16 is not used. These additional reinforcements are formed around the elevator curtain, do we have a way to prevent this in general. Thank you for your attention
There is no difference between solving the raft foundation in parts and solving it in one piece. However, you do not need to divide the raft floors in your project. There are also columns with vertical continuity (only entered on the top floor) in your project. Columns up to the foundation (Columns marked in the screenshot) For the elevator shaft, check the following link:
(1 . answer to the question)
