project control
sefaaydinn
hello, can you check my first project in the appendix with an expert eye. What should I do, what should I change, what should I pay attention to? For example, the raft without amps did not save the foundation thickness no matter how much I increased it and I corrected it by making 70 cm protrusions. Do you think it is appropriate?
Hello, In general, the findings and suggestions for data entry in your project are as follows; -Fix errors in geometry control. -1. Since there are no perimeter curtains on the basement floor, it would be appropriate to enter the upper rigid basement floor number as -2. -R coefficient 4 is entered. If alphaS<= 0.75, R coefficient can be taken as 7 in systems with high ductility level curtains. -If the soil group is A,B,C, "Increase the soil safety stress when using earthquake loads" option can be selected when earthquake loads are used. Good work
Thank you for your answers, I was wondering one more thing, I could not save the foundation in any way if I chose a raft and did not amplify it.
"sefaaydinn":wuvi7pyq" said:
thank you for your answers, I was wondering one more thing for your answers. When the above-mentioned arrangements are made, there will probably be a more economical solution...
Mr. Levent, why are my stairwell results not showing even though I solve the stairs with the structure in the drawing menu? I can read what I should do through the answers given on this subject, can you give a link?
"sefaaydinn":3f339f5l" said:
Levent, why are my ladder results not visible even though I solve the stairs with the structure in the drawing menu. I can read what I should do through the answers given on this subject, can you give the link
"Staircase Reinforced Concrete Calculation Axle in the Stairs Assistant toolbar" You should draw the stair reinforcement axles with the "draw" command.
do you think I made the stairs correctly. When I look at the drawing screen, some of the meriven sections seem crooked, they are due to user error is it? Are the dimensions and dimensions of the equipment correct?
"sefaaydinn":2l2p2xeq" said:
https://yadi.sk/d/W3pzxQL2ocLPw Do you think I made the stairs correctly. When I look at the drawing screen, some of the meridian sections seem crooked and slanted. Are these due to user error? Are the dimensions and dimensions of the equipment correct?
Stair reinforcement axes and reinforcement drawings have been developed for straight-armed staircases in the program.It is convenient to arrange reinforcement drawings of stairs with different geometries using 2D drawing possibilities.
