omerfarukoncel
The program closes when printing. How can I solve it
Log in or register now.
Hello, I think you mean the problem you are having with the dwg export process. This is due to the faulty drawing on the TK27 continuous base. Define the nodal points of the TK27 continuous basis in your project by clicking the left and right nodes of the P09 curtain. It would be appropriate to enter data in such a way that the joint points of the continuous foundations connected to the walls in the rigid direction are at the wall joint points and there will be a continuous foundation under the curtain (For example, the joint points of the TK41 continuous foundations are not on the wall.) In addition; P05-P08 and S04-S06 It would be appropriate to model the continuous foundations between TK18-19 as a single piece."omerfarukoncel":2t8mbi1g" said:The program closes when printing. How can I solve itYou do not have permission to view link Log in or register now.
Could you attach the IdeCAD project file?"MrtGrsl":s5cpeb04" said:Isn't there a solution for this situation?
