profile object command
serkan zorlu
Hello, when I enter the profile object command, my computer is overheating and I have long waits. I encounter the same problem every time.. long waits, annoying fan noise, etc.. I do not have any problems while rendering and other operations.. when I enter the command, I run the fan for a long time, about 2 minutes. I am waiting at full speed, then when I enter the command, I wait for the profile I made. Finally, I'm waiting when I say save the profile to the archive and exit... yet another situation; For example, I made a floor deletion, but when I want to change the position of the floor deletion, when I enter the settings of the object, it gets incredibly tight again.. it really started to become a problem.. Is there a solution? I don't think it's related to my settings, but I still want to ask, is it related to my settings? is it a normal situation? I'm tired, I can't even stand to wait for 15 seconds. If it takes 3 hours to model a building, I swear it takes at least an hour to wait.. Again, waiting for the valuable ideCAD family's help, thank you very much..
"serkan zorb":210rqmpb" said:
Hi, when I enter the profile object command, my computer is overheating and I have long waits every time I face the same problem.. long waits, annoying fan noise etc.. I don't have any problems while rendering and other operations.. When I enter the command, I wait for a long time, that is, for 2 minutes, with the fan running at full speed, then when I enter the command, I wait when I select the profile I have made. Finally, I wait when I say save the profile to the archive and exit... Another situation, for example, I did a double floor deletion. When I go to the settings of the object when I want to change its position, it gets incredibly tight again.. it really started to become a problem now.. is there a solution? I don't think it's related to my settings, but I still want to ask, is it related to my settings? is it normal? I couldn't help it..if it takes 3 hours for me to model a building, I swear I have to wait for at least an hour. again.. Waiting for the valuable ideCAD family's help. Thank you very much..
Hello, ideCAD_Arsiv.mdb located under C:\ProgramData\ideCAD\database\ArchitecturalSections folder file must have grown in size due to continuous archiving... If you delete the file, your problem will be solved. This problem exists in older versions. If you update to 7.020 you will not encounter the same problem again.
thank you very much, i was really overwhelmed.. i am currently updating it on my current computer of 7.019.. i am so happy that i can't thank you enough right now.. thank you very much.. best regards, good work...
