problem copying floors
saridurmus
After completing one floor in a multi-storey structure, the program closes itself when copying is made on other floors and an element such as a wall is entered on another floor. When I remove all the walls, the same problem occurs again.
I found the error. It was due to me. However, there is a situation that is skipped, and if the floor height is different, it is corrected when you make the wall height as it should be. It does not happen when you give a wall height more than the floor height.
