Thank you, did we multiply the reduction coefficient in the core results with the square of 0.85 for the medium level of information. So is the value of this coefficient clear in the regulation? Table 7.1 I saw the information level coefficient for buildings, but I guess it's not. [ /quote] Reductions here mean fconcrete = 0.85 *f core average ________ (0.85 ) Reduction Coefficient fcm = 0.85 * fbeton __________________ (0.85) Cube to Cylinder Conversion Coefficient
				"staticgrass":13ws45fy" said:
			-Will I enter idecad as if I would do a normal static project by checking the modeling of the production from the static project and building in my hand?
 Of course, you can use the project you have. However, you should be sure whether the reinforcements are placed in accordance with the project, especially the tightening of stirrups in column-beam junctions, etc., how much harmony is achieved between the on-site and the project. Then you can analyze accordingly.
				"staticçim":13ws45fy" said:
			-"I think you just trust the concrete quality test. Observe the others yourself." How should I observe the reinforcement myself?
 The answer I gave above answers this question as well. Observe the reinforcements from critical points. Look at the compatibility of the beam reinforcements. Real x-ray and stripping usually give an idea about the column reinforcements. It is not enough on its own.
			-let's say I observed corrosion and if I detected some corrosion in the basement, how do I enter it into the system. In the old versions, when the column and beam properties were entered, there was a corrosion factor in the static/reinforced concrete tab, but I could not find it in the current 8.62 version. Thank you very much, I wish you a good day
 Please see the attached pictures. After all, I would like to say that the interpretation of performance analysis results requires a separate experience. N. YILMAZ
