panel problem?
demir
I use a panel while drawing an elevator. On the ground floor, the panel color is dark, normal, but on the 1st or 2nd floor, the panel drawings appear colorless. I will be glad if you write the reason.
Hello, It is caused by the default light settings of the Perspective screen, as you turn your project in perspective view, you may perceive the color of the panels caused by the shadows differently. But if there is a clear difference in the material, you can send your project to [email protected] and we will examine your project. Take it easy, good work..
If the issue of darkness and clarity in the plan you mentioned is due to the reason in the attached picture, I think. Could the panel scan settings be turned off in the drawing details on that floor?
